1949 0lds rack and pinion
Old Apr 13, 2021 | 01:55 PM
pclocksin's Avatar
anyone have info on installing rack and pinion in 1949 olds 98? my gearbox is bad and original steering is where crossmember for 1972 olds 350 needs to go.
Old Apr 13, 2021 | 02:20 PM
redoldsman's Avatar
Proud Viet Nam Veteran
The 49 Olds has a very antiquated front suspension on it. It has king pins and bushings rather than ball joints. I think the only way you could put rack and pinion on it would be to cut the frame off and put a new clip (I hope we don't go off on the definition of a front clip again) under it. You are talking a massive undertaking.
Old Apr 14, 2021 | 07:37 AM
Tedd Thompson's Avatar
What Red said. Cost would be much much more than having the steering box rebuilt by a expert..... Tedd
Old Jun 20, 2022 | 07:33 PM
pclocksin's Avatar
Went ahead and did it anyway, I fabracated brackets for 1992 cavalier rack and tie rods, and fitted 1976 chev van steering column. now has 1972 olds 350 and automatic with pwr steering. all works good, in 1949 olds 98. also added 1978 master cyl with vacumn boost mounted on firewall
Old Jun 20, 2022 | 07:34 PM
pclocksin's Avatar
boese1978
Jan 9, 2019 11:35 AM
sixties-forever
Ninety-Eight
May 18, 2018 05:00 PM
1952Olds98
Feb 4, 2015 03:25 PM
Guttermouth
Wheels and Tires
Sep 22, 2011 11:49 AM
redoldsman
Apr 18, 2009 06:57 AM
