1947 front suspension issues
Old Apr 16, 2020 | 09:17 AM
JoeyOldsmobile's Avatar
Hey everybody,
I have some issues with the alignment of my front suspension.
I had a lot of play on the shocks (and the were leaking) and on the lower control arms.
I have replaced all the bushings, kingpins and shafts for new ones and bought refurbished action shock levers.
Now when putting it all together my uprights won't fit into the control arms.
As you can see on the pictures below the lower control arm is too much to the left, or the shock should be more to the right.
Force mounting it together is almost impossible and really doesn't feel healthy
I have this issue on both sides.
The car is straight and has no frame issues as far as I can see.
All the shafts are hand tight without any play (as wel as in the shockmount as the shaft on the lower control arm) and everything has been put together what seems to me a normal order.
Am I missing something here? Is there a trick to it to adjust the lower control arm?
Just to let you know that the left and right shock are not interchanged :P
Hope you guys can help me out, would like to drive again.
Old Apr 16, 2020 | 02:08 PM
Mark Desing's Avatar
From the picture it doesn't look like the upper steering knuckle support is in the middle,
Old Apr 16, 2020 | 02:15 PM
​​​​​​​Yes indeed, I checked and it's 2,5mm off center. I'll correct that but that still won't make up for the big gap underneath.
I ordered a shop manual but this will take a while before it gets here. If anybody who has a sho manual could check for clearances etc. on installation that would be great!
Old Apr 16, 2020 | 03:15 PM
Charlie Jones's Avatar
Phantom Phixer
The steering knuckle supports are not identical . They are different from left to right .
Perhaps you have them on the wrong side of the car .
Old Apr 16, 2020 | 03:51 PM
nope triple checked, left and right are not mixed up...
Old Apr 16, 2020 | 05:59 PM
Phantom Phixer
We are talking about the knuckle supports , right ? Not the shock absorbers .
Old Apr 17, 2020 | 12:35 AM
Indeed the knuckle support. I have a ‘47 which has the shock absorber in the upper control arm as you can see.
i know left and right are different but they are not mixed up.
Old Apr 21, 2020 | 09:58 AM
Thanks for the replies. I'll have a look into it.
All my parts will be painted before final fitting, i'm just testing it out now :P.
I'll let you know how far I'll get this week.
Joey
Old Jul 27, 2020 | 02:50 AM
Cadillacrazy's Avatar
did you get those lower bushes out or did a shop do it because if there is an easy way of doing it I want to know as mine are in so tight nothing wants to move.
Old Jul 28, 2020 | 06:07 AM
I got mine out. If they won't move, preheat with a torch.
Old Jul 28, 2020 | 09:18 AM
al1950's Avatar
how did you refurbish your shocks? mine our worn out on my 1950 88,, any info details appreciated , thanks Allan
Old Jul 29, 2020 | 01:16 AM
1947 steering box?
My 1947 steering box has the pitman arm coming out of the top....is that how they were or is mine odd? Never seen one this way?
johnnyrockets
Jun 22, 2019 06:50 AM
62 Cutlass Convert
Tech Editor's Desk
Jun 11, 2015 09:15 AM
johnnyjaws
Suspension & Handling
Jun 16, 2014 08:48 PM
ithaca4me
Jul 30, 2011 02:26 PM
oldzy
15
Feb 4, 2011 06:58 PM
