1938 L38 Question
Old Jan 17, 2021 | 02:03 PM
CarWizard's Avatar
1938 L38 Question
Picking up a nice 1938 L38 with straight 8 tommorow. Id like to set it up with better highway gearing. Ill never exceed 60-65mph. So are there OD 3 speeds that will bolt up to the flathead 8? Or should I change out the rear end carrier for one with better gearing? I dont want to modify it too much, a little is fine. But no 700r4 swaps.
Ill post pics when I get it to my shop. Thanks guys.
Old Jan 17, 2021 | 02:32 PM
rocketraider's Avatar
Oldsdruid
I think rear end gearing is a better approach as a lot of prewar cars had gearing deep in the 4's. But I don't know where you'd find taller gearsets.
Old Jan 17, 2021 | 02:50 PM
CarWizard's Avatar
Thanks for the info. I wonder if other GM brands had similar rear axles that I can hunt for a carrier in the 3.2 - 3.7 range of ratios.
Old Jan 17, 2021 | 04:45 PM
Charlie Jones's Avatar
Phantom Phixer
The rear center sections can be changed for a Hydra-Matic rear section .
'37 thru '47 Olds or Pontiac rear centers will bolt right in .
'48 thru '54 Olds or Pontiac centers can be installed in earlier axle housings with a few mods.
The bolt pattern is the same but the bolts are one size larger . Dorman makes a double ended stud that will allow you to bolt it up .
The '48 and up ring gear is slightly larger .
The notches in the axle housing flange have to be ground out about 1/8 inch to allow the ring gear to clear the housing .
I did this swap years ago on a '37 Pontiac with a 4.37 ratio .
I installed a center from a '54 Pontiac with Hydra-Matic with a 3.23 ratio .
The car cruised easily at 65 MPH , but if you hit a steep hill , you were looking for second gear a little sooner .
Old Jan 17, 2021 | 05:56 PM
CarWizard's Avatar
And the notches in the axle housing flanges have to be ground out about 1/8 inch to allow the ring gear to clear the housing .
Thank you very much. This is the exact information I needed. I will search for a 3.23 carrier. I will post pictures of my new purchase for everyone soon. The oldest car Ive ever owned before was a 1955 Buick Special with a 264/3spd. 1938 is stepping much further back. I am very excited
Old Jan 18, 2021 | 03:03 PM
TommyTheCat's Avatar
Didn't you own a 50 Rocket 88 really briefly ? You mentioned it briefly in your video of all the cars you have owned, but the Olds was just more work than you wanted.
Old Jan 18, 2021 | 03:13 PM
CarWizard's Avatar
Yep. It was too far gone. And I didnt own a shop then either. Lol.
Old Jan 18, 2021 | 04:16 PM
Funkwagon455's Avatar
Talking
Thank you “phantom phixer”, this is good information for me as well with my stump pulling, three speed manual’40!
Old Feb 10, 2021 | 10:41 AM
Russ Golesh's Avatar
I installed a 3rd member from a 1950 Oldsmobile with Hydramatic trans into my 1937 L37. The original gearset is a 4:37. The '50 is 3:42, a perfect cruising gear ratio. At 65mph, RPM's are now a bit over 2500.
Mikeg
Mar 23, 2016 05:12 AM
Rocketowner
Site Suggestions
30
Mar 17, 2016 11:05 AM
frasco
Drivetrain/Differentials
Feb 12, 2012 01:01 PM
michael hilsabeck
Sep 28, 2011 08:46 PM
nonhog
Site Suggestions
Jul 26, 2011 08:09 AM
