1938 L38 Question
1938 L38 Question
Picking up a nice 1938 L38 with straight 8 tommorow. Id like to set it up with better highway gearing. Ill never exceed 60-65mph. So are there OD 3 speeds that will bolt up to the flathead 8? Or should I change out the rear end carrier for one with better gearing? I dont want to modify it too much, a little is fine. But no 700r4 swaps.
Ill post pics when I get it to my shop. Thanks guys.
Thanks for the info. I wonder if other GM brands had similar rear axles that I can hunt for a carrier in the 3.2 - 3.7 range of ratios.
The rear center sections can be changed for a Hydra-Matic rear section .
'37 thru '47 Olds or Pontiac rear centers will bolt right in .
'48 thru '54 Olds or Pontiac centers can be installed in earlier axle housings with a few mods.
The bolt pattern is the same but the bolts are one size larger . Dorman makes a double ended stud that will allow you to bolt it up .
The '48 and up ring gear is slightly larger .
The notches in the axle housing flange have to be ground out about 1/8 inch to allow the ring gear to clear the housing .
I did this swap years ago on a '37 Pontiac with a 4.37 ratio .
I installed a center from a '54 Pontiac with Hydra-Matic with a 3.23 ratio .
The car cruised easily at 65 MPH , but if you hit a steep hill , you were looking for second gear a little sooner .
And the notches in the axle housing flanges have to be ground out about 1/8 inch to allow the ring gear to clear the housing .
