O type rear end
Old October 31st, 2014, 05:54 PM
Chevydude9219's Avatar
O type rear end
I have a 69 f85 cutlass with a 455 and 350 trans. This winter I am going to be putting a mondello 4150 possiflow intake, 750 street demon carb, and a xe274 cam. My rear end is the stock 3.08 open carrier o type. I want a posi. Who sells parts? Are they affordable? Better off to just get a true 12 bolt? Rear ends are not my thing. Don't know a whole lot about these o types
Chevydude9219 is offline
Old November 1st, 2014, 07:12 AM
2blu442's Avatar
There's not much available for the Type O which has an inspection cover with 12 bolts and a ring gear with 10. These are strong rear ends and wouldn't have any trouble surviving behind a 455. Unless your TH350 has been beefed up, that may be the weaker link.
You can put in a different rear end from other 64-72 GM A-body cars but may need to change the driveline and/or U-joint. Olds used a bigger u-joint than chevy, but there is an aftermarket joint available with two Old and two Chevy caps on it.
Check for a member named monzaz, he sells new and used parts and is one of the resident gurus of differentials. He can tell you what he has available for your car at this time.
John
2blu442 is offline
Old November 1st, 2014, 08:18 AM
Justin
oldstata's Avatar
Yes check with Jim he can walk you threw a swap
They take a posi from a ford 8.8 machine it to fit into the olds 12 bolt and you use your old gears
I think some gears are not currently offered ? But I have seen a thread were they might be you can also ask brain (507olds )
oldstata is offline
Topless72
November 22nd, 2020 11:01 AM
350TurBRO
September 12th, 2014 11:52 AM
MightyMouse61
Drivetrain/Differentials
February 27th, 2011 05:00 PM
Aron Nance
September 14th, 2010 05:37 AM
Qwik71442
May 26th, 2010 10:58 AM
Quick Reply: O type rear end
