Torque converter hub diameter
Old Mar 25, 2022 | 11:08 AM
Mj119's Avatar
I just got done resealing a th400 out of a 1976 98 to replace the th375 in my 65 cutlass, the torque converter from the th400 had some dirt in it from sitting off the transmission for some time before I got it. So I bought a cheap one from orieleys. It says it will work on a 1976 98 with a 455 but the outer diameter is 1.75" rather than the 1.875 on the comverters from the th400 and th375. I am leaning toward returning the new one and using the one off the th375 since it's clean inside and out. My question is am I wrong in assuming the new converter with the smaller od on the hub won't work. I can't imagine it will seal, I also couldn't get it over the splines but don't have a good way to measure down inside the converters. Thanks for looking.
brotherGood
Mar 18, 2022 05:35 PM
shamusj
Jan 24, 2022 09:48 AM
jpayne_80@hotmail.com
Sep 1, 2017 07:19 AM
VinMichael
Jul 22, 2016 04:32 PM
montvaleplace
Apr 8, 2011 01:52 PM
