Correct shifter cane for 68 442?
Old May 31, 2019 | 11:00 AM
matt506's Avatar
The current shifter I have is bent and has just hurst embossed on it. What should the original look like and what shifter ball is on it? I see some with a H and 442 on them advertised as correct. Mine does have a floor counsel. Thanks matt
Old May 31, 2019 | 07:26 PM
Yellowstatue's Avatar
Should have 442 on it and a plain black ball with a console. Should have a curve. What are you referring to as bent?
Old May 31, 2019 | 09:26 PM
matt506's Avatar
Well I know of the curve but the one one mine now has a curve to the right and the normal curve back. My counsel does not fit on it either.
Old Jun 1, 2019 | 05:27 AM
35tac's Avatar
1966-1969 Hurst shifter bar should have 442 and "H". Would have round shoulder on ball thread. Should be marked part number 3760. Your description of current shifter stick sounds like 70 to 72. Part number 7169 is for bucket seat and console. #7305 is for bench seat no console. I got this information from a book " Good Old Days Olds 64-72 A-Bodies" by Mike Siedlek page 59 & 60. My scanner is down so I can't copy it. Hope this helps.
Wayne
Old Jun 1, 2019 | 05:49 AM
rob1960's Avatar
Like Wayne said it should have both an "H" & 442 on it. It obviously does curve back towards the driver but there are no "bends" left or right. It's a "flat stick" unlike the ones for '70-72' that have bends in them. I painted the H & numerals on mine just for a bit of color & like others said it's supposed to have a plain black ball form the factory with a console. Non console cars had the black ball with the shift pattern. White ones were never offered from the factory but everyone uses them 'cause they look better. I'm using a vintage white Hurst t-handle on mine these days.
Old Jun 1, 2019 | 08:09 AM
matt506's Avatar
Thanks guys yup it seems mine is a 70 to 72 version will check numbers in a bit. Wonder then if the shift gat is later to?
I know the trans is dated to the car.
I bought a cane and ball as you guys mentioned for about 140 and they are own good shape. Paid to much?
I’ll pull my old one verify numbers and sell accordingly, by the way that looks totally awesome painting the numbers and letters.
Old Jun 2, 2019 | 03:48 PM
matt506's Avatar
Well I take that 70-72 thing back. Pulled the boot and looked and yes cane is not original but it seems that the jog to the right is from some weird bracket on this shift gate. Seriously think this is a bubba job. Matt
q
Old Jun 2, 2019 | 05:54 PM
crash's Avatar
The shifter in the picture above is not a "Bubba"...
Its a 1968-72 Chevelle after market shifter you would buy from a speed shop...
If you check the base of the bolt on stick it should be number 8009...
Hope this helps... Crash
Old Jun 2, 2019 | 07:48 PM
matt506's Avatar
Crash yup helps a ton, thanks now to figure out if my transmission is Chevelle too.
Old Jun 2, 2019 | 09:04 PM
crash's Avatar
E-mail me at crash_enterprise@yahoo.com
I can tell you about the trans codes..
Crash
Old Jun 4, 2019 | 04:39 AM
allyolds68's Avatar
I don't know how soon you're looking for one but I have the correct 68 442 shifter (actually used late 66 to 69). It's in my car now but I'm going to be switching it out in the next month or so for a nicer one that I have.
Old Jun 5, 2019 | 03:48 AM
matt506's Avatar
I bought a shifter set up but if yours is ok and date coded closer to my build date I’d be interested sir.
Old Jun 5, 2019 | 04:01 AM
matt506's Avatar
Old Jun 5, 2019 | 06:22 AM
crash's Avatar
Matt, What date code are you looking for I have several of these OEM Olds Hurst shifters???
Thanks... Crash
Old Jun 5, 2019 | 06:55 AM
matt506's Avatar
Well from what I have learned is that my car was made 4th week of April 68. 04D
And from my question as to parts dates for as pacific time from most parts should be 2 weeks before April 20th but it earlier than say March 68? That’s what I understand.
What would a date code of 9 7E2 mean? Matt
Old Jun 5, 2019 | 08:05 AM
crash's Avatar
I have a Feb. of 1968 shifter, re-built, re-plated, and re-chromed handle...
Thanks... Crash
Old Jun 5, 2019 | 08:23 AM
matt506's Avatar
Sounds pretty good how much would this be?
Old Jun 5, 2019 | 08:53 AM
crash's Avatar
$550.00 plus shipping... Crash
Old Jun 5, 2019 | 10:01 AM
matt506's Avatar
Very interested I’ll need to liquidate the chevelle one and spare then add a little. If your in for a quick sale I’m out but in no hurry I’ll work on getting it from yah. Matt
Old Jun 5, 2019 | 12:40 PM
crash's Avatar
I do take trade-ins... E-mail me some pictures... crash_enterprises@yahoo.com
Thanks... Crash
Old Jun 8, 2019 | 08:42 AM
matt506's Avatar
Crash
i texted the pics to you still learning the iPhone when emailing pics. Matt
Old Jun 8, 2019 | 09:25 AM
crash's Avatar
9 7 E2 is a Sept. 1967 for an early 1968 model car...
What about pictures of the linkage and mounting plates for both shifters???
Thanks... Crash
Old Jun 8, 2019 | 10:19 AM
matt506's Avatar
Yup I think mine is not early enough but we’ll see. Here is the one plate that is on the car with the chevelle shifter and linkage. The 442 shifter I did not have plates or linkage with it.Ill send picks of both this afternoon.
Old Jun 8, 2019 | 03:31 PM
matt506's Avatar
Ok here are the linkage and mount plate I have for the car
Old Jun 27, 2019 | 08:09 AM
DPosey's Avatar
Do you still have that 442 rebuilt shifter for sale ?
Old Jun 27, 2019 | 09:38 AM
matt506's Avatar
It is still available but we found out it is for a 70 chevelle that’s why I was asking.
Old Jun 27, 2019 | 09:39 AM
DPosey's Avatar
K. Thx. Will keep looking for one period correct.
Old Jun 27, 2019 | 09:43 AM
matt506's Avatar
I know I have one but there is a completely redbone one that a friend on the forum has. Pricey but top notch restoration can send contact info. Matt
Old Jun 27, 2019 | 09:51 AM
DPosey's Avatar
If you could pass my info to him.
Have him email me directly.
DPoseyDVM@yahoo.com
Thank you for your help.
Doug
Corpus Christi, Texas
Dave Siltman
Aug 3, 2019 12:45 PM
Pap
Jun 1, 2016 12:21 PM
Eddie Hansen
Dec 19, 2014 07:23 AM
bobfo1
Aug 8, 2012 02:52 PM
68Tom
Apr 25, 2008 10:06 AM
