Removing crossmember from a 1975
Old Jun 14, 2018 | 12:40 PM
cstalnaker's Avatar
Does anyone know how to remove the transmission crossmember from a 1975 Cutlass Salon? I have to replace the transmission & can not get the crossmember out, it it hits the floor pans or something no matter what I try.
Any suggestions would be appreciated.
Old Jun 14, 2018 | 05:12 PM
RetroRanger's Avatar
72 Olds CS
im not familiar w the 75 but most just unbolt from the frame and trans and slide out.
Sometimes the frame can be bent from someone jacking on an unboxed area of the frame if this is the case just bend the frame back w a big crescent wrench or similar
Old Jun 14, 2018 | 06:44 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Remove the rubber trans mount from the trans or the cross member. Lower the exhaust head pipe(s).
Chris'cutlass
Aug 31, 2018 12:40 PM
Carsick
30
Dec 10, 2015 07:33 PM
johns65442
Feb 1, 2014 10:52 AM
Al Graaf
Mar 26, 2012 09:36 PM
Gary's 2 442-S
Apr 11, 2011 09:52 AM
