70' Cutlass Supreme Column Shift Problem
Old Sep 7, 2017 | 05:40 PM
tgilligan's Avatar
Hi All,
My 70' CS has what I believe to be the TH350 trans with automatic column shift. I'm working on several items and yesterday attempted to pull it out of the garage and found a shifter issue. Park seems to work fine but every other selection on the column seems to be neutral. I say that not to say it's definitively neutral gear but every gear I put the selector in, I press the gas lightly and the engine simply revs but nothing engages. I don't feel it engage into any other gear, including reverse and looking for things that I should be checking. This has been a project car for years and I've never been able to drive it yet so I can't say that the trans was working or not before but looking to see what I can do to rule things out.
Old Sep 7, 2017 | 05:52 PM
My2nd 69 442's Avatar
Check fluid level first
hvysupreme
Feb 18, 2017 12:40 PM
David DeCan
Jan 23, 2016 09:10 AM
Rocketbrian
Oct 2, 2013 10:18 AM
Bitburger
Dec 30, 2012 04:49 PM
ros6872
Feb 24, 2010 05:50 PM
