Transmission crossmember and mounting bolts
I am ready to install the engine and transmission. I am searching for the correct size bolts for the bellhousing and the four bolts that mount the crossmember to the frame and the four bolts that mount the rubber mount to the frame and transmission tail. Im guessing that they all need to be type 8?
Anyone have a "shopping list" so I can go to the buckets at the hardware store instead of buying a "kit" with overpriced items?
1. crossmember bolts (4)
2. Transmission to rubber mount (2?)
3. Rubber mount to the crossmember (2? or 4?) I have a th200 4r
4. tranmission to the engine 4? 6? I am not sure.
I found out what bolts I need for the engine mount to the engine.
I also have enough of the transmission bellhousing to engine bolts that I think I can match those...
I just need help with the transmission crossmember and rubber mount to tranny AND the convertible crossmember to chassis. Any recommendations for sizes and threads?
Crossmember to chassis is usually a 3/8x16 by an inch long, 2 per side. Metric 10x1.5mm by 25mm long will work as well. Include lock and flat washers.
Mount to trans on a 2004r is metric, use two 10x1.5mm by 25mm here with flat washers.
The two bolts for crossmember to mount varies, take the mount to the hardware store and find what fits, use washers. Some mounts have a stud on the bottom and you'd only need a nut and washer. In either case, could be metric or standard.
stanzaschance
July 28th, 2015 06:38 AM
russroyce
August 27th, 2014 05:27 AM
