Trans rear decode 71 442 convertible
Old Feb 23, 2025 | 01:46 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Trying to figure out my rear end ratio at 60 miles an hour if Speedo and tach are accurate.
at 60 miles an hour i’m about 3300 RPM and at 70 miles an hour. I’m at 3800 RPM thought maybe it was like 373 or higher?
OG trans seems correct for 71
71 olds 442 convertible
Old Feb 23, 2025 | 02:13 PM
Mr Shifty Sidney's Avatar
SC is 3.08 non posi
Don W
Old Feb 23, 2025 | 02:42 PM
Tri-Carb's Avatar
Use a GPS to verify your speedometer readings.
Old Feb 23, 2025 | 03:29 PM
Olds Specialist LOL
yes, I usually do. I have to download a new app. I just haven’t done it yet. Thanks. I can’t believe it’s a 308. I could feel the car revving at 3800. So someone changed the gears gotta be.
Old Feb 23, 2025 | 03:31 PM
Olds Specialist LOL
Originally Posted by Mr Shifty Sidney
SC is 3.08 non posi
Don W
I can’t believe it’s 308 the way the car feels. It’s gotta be higher. Someone must’ve changed the ring and pinion. I’m gonna double check my speedo and tach
yes, single spinner way more fun than a posi. If I go around a turn, I could hit it and then the tire just smokes. Haven’t done it on this one yet but you get the idea ha ha
Old Feb 26, 2025 | 02:22 PM
And the tach.
Old Feb 26, 2025 | 05:07 PM
Axle tube stamps/markings are listed in the CSM.
Old Feb 27, 2025 | 06:32 AM
GN1220's Avatar
Jack it up and count the revolutions of the diff and tires and calculate, that will get you close.
Old Feb 27, 2025 | 03:32 PM
Without knowing tire diameter it is impossible to provide useful information. And that's outside diameter of the tire, not the wheel diameter.
Old Feb 28, 2025 | 03:59 AM
deadeyejedi's Avatar
Those numbers seem more like 411 gearing i would guess the rear ratio was changed . as Joe mentioned tire size would help.The best way to clear it all up would be to pull the diff. cover and see ,an opportunity to inspect ,change the fluid and gasket
Dunham
Jun 9, 2024 10:17 AM
Bigmikey65
Feb 25, 2022 09:21 PM
OLDsBARRY
Nov 23, 2021 07:25 PM
OLDsBARRY
Aug 22, 2021 08:13 AM
dsolomon
Nov 20, 2011 02:43 PM
