ROTO 5 - Help
ROTO 5 - Help
Hi guys,
1962 Oldsmobile Cutlass F-85. I have the Roto 5 transmission in the car. We just got the car tuned and running right. Now it is spewing trans fluid from the vent. We had re-routed the vent and plugged it, so the trans fluid started coming up out of the dipstick.
Besides the Roto-5 being a turd, any idea whats going on here?
Thanks,
Al
Thanks,
Al
If the level is correct I would bet the governor went bad. Can't be sure of this? The original is aluminum and the replacement is cast iron. You likely need a rebuild either way. If you rebuild it and the governor is not bad you need to replace it with a cast iron one anyway if you can find one. I do have an extra one that is NOS if you find you need one.
dantana
Aug 17, 2012 07:00 PM
old.n.bold
Apr 1, 2009 01:56 AM
