Need help identifying my rear end
Old November 30th, 2023, 10:18 AM
SRV8's Avatar
Hi I need help identifying my rear end. It is in a 1972 olds cutlass supreme convertible, Rocket 350 with TH-350, need to know which axle typ it is because want to install posi in it and which I should order
SRV8 is offline
Old November 30th, 2023, 11:15 AM
That's the Oldsmobile version of the Corporate 8.5" ten bolt used under every Cutlass Olds built in 1971-72. Bolt-in axle shafts, so the bearings and seals are different, but otherwise identical to the Chevy 8.5" 10-bolt. "SA" is the 2.73:1 open axle.
joe_padavano is offline
Old November 30th, 2023, 11:34 AM
SRV8's Avatar
Ji Joe I
ask because of the housing here it looks different to other 8.5 axle GM and how many spline has it stock
thx for your help
SRV8 is offline
Old November 30th, 2023, 03:05 PM
Don't worry about those "horns". Look at the side of the center section for two parallel ribs, the front sides of the center section for a cast in block "O" that is the identifier for an Olds version of the corporate 10 bolt rearend, and the top of the center section for a drilled boss where the brake junction block bolts on. I think the Buick version (that sometimes was used in the Cutlass line) has an A instead of an O, but is essentially the same.
Oh yeah, and that 407296 casting number is a dead giveaway.
Fun71 is online now
Old November 30th, 2023, 03:21 PM
SRV8's Avatar
Hi does the axle have standard 28 or 30 splines
SRV8 is offline
Old November 30th, 2023, 03:38 PM
Rocket Renegade!
Have you tried using both hands and a flashlight?
BangScreech4-4-2 is offline
Old November 30th, 2023, 03:46 PM
...and, a mirror comes in handy. I'll grab a cookie on my way out....
Vintage Chief is offline
Old November 30th, 2023, 04:30 PM
28 spline.
Fun71 is online now
Old December 1st, 2023, 03:29 PM
Originally Posted by bangscreech4-4-2
have you tried using both hands and a flashlight? :d
matt69olds is offline
Olds68swede
Drivetrain/Differentials
January 11th, 2022 01:52 PM
tkcutlass
24
March 27th, 2021 07:42 PM
scottr2200
June 23rd, 2020 09:20 AM
Nasty455
20
May 5th, 2012 04:07 PM
72CUTTY
February 11th, 2012 07:13 PM
Quick Reply: Need help identifying my rear end
