leaking speedo cable at trans
Old Dec 8, 2023 | 10:39 AM
ej69's Avatar
1969 cutlass
i am getting a drip out of the end of the speedo cable housing that screws into the speedo gear housing cover on trans (th350). i replaced the gear housing 5 yrs ago when swapped out speedo gears in trans. Fluid is dripping out of female housing end of cable. Would a worn speedo shaft not be making a good seal with small o ring in the housing? Like i stated, the speedo gear housing and seals are only 5 yrs old. Speedo cable is original.
thanks eric
Old Dec 8, 2023 | 01:11 PM
The only way to know is to pull the housing and driven gear and inspect them. At that point, you MIGHTASWELL replace the seals on the housing when it's out.
Old Dec 8, 2023 | 02:04 PM
Sugar Bear's Avatar
Agree with replace the seals and yes it can be a worn driven speedo gear. If available I'd replace the both the seals and the driven gear.
BTW, that undercarriage looks quite respectable! Did you finish it?
Old Dec 8, 2023 | 02:14 PM
Burd's Avatar
Old Dec 8, 2023 | 02:55 PM
ej69's Avatar
Figure replacing seals, just disappointed only lasted 5 yrs from repair.
yes I did restoration around 10-12yrs ago.
bigron111
Sep 22, 2018 06:39 PM
stephenca118
Aug 13, 2017 08:06 AM
Mike_ATX
Oct 28, 2014 07:56 AM
OldsCutlass70
May 2, 2013 09:29 AM
ej69
Mar 22, 2010 03:28 PM
