Hurst lightning rod shifter parts
Old Mar 17, 2021 | 06:46 PM
Buckley778's Avatar
hi does anybody know where I can get the cables that control the shifter buttons thanks
Old Mar 17, 2021 | 08:22 PM
HighwayStar 442's Avatar
I think you are not looking for the transmission cable to LR. Been a long time since I work on mine.
It is just a airplane cable that fits snuggly in the button and the spring loaded pin with a key on the side at the bottom. Both held in place by tightening allen screw. Cable is short enough to be stiff yet flex a little for the bend in the shaft. Add some white lithium grease when you finish. Take one of the parts to hardware store, for a snug fit cable. I do not know how long. But you should be able to get the correct length in a couple of tries.
Try below, may have parts and /or know the thickness and length of cable.
http://precisionpontiac.net
88hurstolds on this site
Big Johnson
Aug 6, 2019 11:17 AM
BADGAS
Jun 26, 2018 01:04 AM
67w30
Feb 6, 2011 02:52 PM
OLDS 83
Jun 10, 2010 06:34 PM
