How much front to rear play should a driveshaft have?
Old Jun 7, 2023 | 04:50 PM
Tjohn8573's Avatar
Have much play from front to rear should a driveshaft have. I have 1968 4442 with a 4 speed tranny. My current driveshaft is 56” from center of u-joint to center of u-joint. I thought it was an original OEM driveshaft. It is not that easy to take in and out and probably has at the most 1/2” forward and back play when unbolted. How much back and forth play should I have? I thinking more like an inch would be more correct but want to check what others think.
Old Jun 7, 2023 | 05:00 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I guess I am not understanding your question. With the driveshaft bolted to the differential, there should be no forward and backward movement.
Old Jun 7, 2023 | 05:07 PM
BillK's Avatar
If I am understanding you correctly if you unbolt the driveshaft at the back U-joint it will only move forward 1/2" before it bottoms out in the transmission ? That just barely sounds like enough to get it out of the yoke. I think it should be more like an inch. It also depends on if you are doing it with weight on the wheels or with the car hanging on a lift with the rear wheels hanging down.
Old Jun 7, 2023 | 05:26 PM
Tjohn8573's Avatar
Yes this is exactly what I am talking about. It barely enough to get it out of the rear yoke. And it is with the wheels on the ground and full weight of the car.
Old Jun 7, 2023 | 06:57 PM
BillK's Avatar
That is probably on the tight side but if it is with the weight on the wheels it will probably be fine. If you put the car on a lift with the wheels hanging it will be easier to get the shaft out. Unfortunately the only way to get more clearance is to cut the yoke some or have the driveshaft shortened. If you plan on aggressive driving it would probably be a good idea to do something about it. You don't want the yoke bottoming out in the trans.
Old Jun 7, 2023 | 07:07 PM
Tjohn8573's Avatar
Thanks for your thoughts! I was debating whether I should get it shortened by 1/2” or 3/4”.
Old Jun 8, 2023 | 04:39 AM
jmcghee's Avatar
the general consenses is 3/4 to an inch of clearance. Google how to measure a driveshaft. There are numerous DRIVE SHAFT BUILDER websights detailing how to measure properly
Old Jun 8, 2023 | 12:02 PM
Run to Rund's Avatar
Some driveshaft mfg say 1" minimum, 1.25" is ideal.
Old Jun 9, 2023 | 10:00 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Length needs to be enough to keep the slip splines engaged at full suspension travel and not bottom-out on yoke/tail shaft at full suspension compression.
tkcutlass
Drivetrain/Differentials
Mar 19, 2022 08:35 PM
Bassemaa93
Jul 16, 2016 01:30 PM
1968_Post
Oct 2, 2014 05:18 PM
70442
Mar 17, 2013 10:05 AM
matviar
Feb 11, 2012 07:19 AM
