How can I tell what transmission is in my car
Old Oct 12, 2013 | 02:54 PM
Archer Meredith's Avatar
Hi I have a 1972 olds cutlass 350 rocket 4bbl and I don't know what trans I have does not have kick down linkage just 1 vacuum line going down to the trans does this mean I have a 400 turbo
Old Oct 12, 2013 | 02:57 PM
Cutlass 350 from the factory would have a TH350 trans. Are you sure your kickdown linkage isn't just missing?
Old Oct 12, 2013 | 03:01 PM
It could be missing but it does not look like there any thing missing from either side of the carburetor
Old Oct 12, 2013 | 03:02 PM
don71's Avatar
same but different
That sure sounds like a th400.
The th350 pan is square with one corner cut off.
The th400 pan is an odd shape. Some people say its "looks like the state of Texas"
Old Oct 12, 2013 | 03:07 PM
11971four4two's Avatar
MOTORHEAD
the th-350 detent cable attaches to the gas pedal
Old Oct 12, 2013 | 03:08 PM
http://www.technicalvideos.com/ident...smission.phtml
Old Oct 12, 2013 | 03:28 PM
I will definitely look at the oil pan
Old Oct 12, 2013 | 03:36 PM
I thought the kick down linkage for the passing gear was attached to the linkage for the carb
Old Oct 12, 2013 | 03:50 PM
4speed455's Avatar
Not on Olds. They use a cable on the gas pedal just above the throttle cable. Look at your pedal if there are two cables it a 350. If there is an electric switch then it's a 400.
Old Oct 12, 2013 | 03:57 PM
I will look for that thanks
Old Dec 26, 2013 | 06:26 PM
Outlaw88's Avatar
Outlaw88
I've got a similar question, the trans in my car came out of a 85' Delta 88, its the 4 speed w/OD, what is the "name" of that trans??
Old Dec 26, 2013 | 07:27 PM
Originally Posted by outlaw88
i've got a similar question, the trans in my car came out of a 85' delta 88, its the 4 speed w/od, what is the "name" of that trans??
200 4-r
79MKII
Jun 12, 2012 07:22 AM
mscofer
Apr 4, 2010 06:35 PM
Atdog
Jan 25, 2009 10:48 PM
Oldsguy
Jun 24, 2008 07:08 AM
shaks 442 clone
Feb 19, 2008 04:51 PM
