grinding clunking noise
im hearing a loud noise under my car i have some videos here. it also doesnt like going in reverse it will engage but once i start moving it starts shaking a bit car turns on no problem and revs in park no problem
looks like your pinion nut somehow backed off and allowed the yoke to separate from the pinion gear. the nut is supposed to be torqued on to the pinion tight, so not sure how this could happen. if its just the nut, then you could be rel lucky and just find another nut to replace the one you lost.
its in the center of the driveshaft yoke. i think it is a 1 1/8" diameter nut if i remeber right. it bolts the driveshaft yoke to the splined pinion shaft you see sticking out of your rear differential. the yoke is splined too. they slide over one another and the nut holds them together. your yoke is hanging loose and the splined pinion gear is showing sticking out of the diff. if your real lucky the nut might still be there hanging loose in the yoke.
you will need to unbolt the driveshaft from the pinion yoke and then slide the pinion yoke back over the splined pinion sticking out of the diff. its the only way you to get a 1 1/8" socket over the pinion nut to tighten the yoke to the splined pinion. once that assembly is back together and the nut is torqued to spec., then you bolt the driveshaft back onto the pinion yoke. fill the diif up to the drain plug level with 80w90 gear oil and your done.
If you are unable to locate elsewhere, McCaster-Carr is a good source for washes, seals, fittings, fasteners, joints, etc. Here are their crush washers ... only bad thing is sometimes the quantity which you need to purchase if you want just one.
https://www.mcmaster.com/#crush-washers/=1ch0crj
If you were driving it like that when it was loosening up chances are pretty good you damaged the ring and pinion gear. Take the cover off and have a look before ordering anything. I've seen this happen with newer mopars, truck in particular and it makes a mess of the ring and pinion. The pinion actually ends up grinding into the carrier and so on
Dennys Driveshafts
http://www.dennysdriveshaft.com
At a minimum, you should pull the inspection cover and look at the gears and inspect for debris. Chances are you're in for a bit more fun. Inspect the pinion splines and U Joints as well. You might get lucky?
If it was me the entire rear end would come apart for inspection. Chances are high the pinion bearings have been affected. At that point, you're committed to a full rebuild...IMO.
Follow up and let us know how it goes to close this thread.
Last edited by droldsmorland; Apr 18, 2018 at 05:22 PM. Reason: 70Green typed quicker than I
CutlassS1972
18
Aug 13, 2015 11:08 AM
