full size posi rear
Old Dec 16, 2012 | 06:32 PM
71 delta88guy's Avatar
full size posi rear
Hi. I have a 72 delta88 posi rear,3:08 gear. I'm taking the brackets off to transfer to a ford 9 inch. Anyone need the remnants? Posi clutch pack has 5k on it-bought new from gm when they were still available. Aslo new brakes. I'm in northeast ct.Going to be available for pickup in january-probably late in the month.OR if someone has another rear they want to give me for the brackets you can buy mine complete. Thanks. I didn't post this in for sale cause it's kinda odd. Hope this is ok.
Old Dec 17, 2012 | 09:02 AM
Seems like a real shame to hack up that rear just for the brackets. You could probably swap for a relatively worthless open rear pretty easily.
Old Dec 17, 2012 | 03:57 PM
I used to have 5 delta88's.Now I'm down to just the 1 and have no other option at the moment. If I had an idea that someone here wanted this rear I could look locally for a pos 1 legger, know what it would cost and sell my posi to someone.But I mean it's just not that hard to swap out a carrier. Yank axles,pull carrier,change over ring gear and your in business. Thanks for the reply.
Old Dec 20, 2012 | 04:41 PM
So nobody in the new england,northeast needs this rear end. Ok fine. Anyone need the carrier or the gears,axles,brakes? About 2 weeks from cutting up this rear. It's still in the car. You can drive it before the swap. Last chance.
Old Dec 20, 2012 | 05:37 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
What would you like for the posi carrier and gears? I have a 2.92 at the moment, but it never hurts having a spare around.
64Rocket
Aug 14, 2013 06:49 AM
mbrae5
May 10, 2013 07:12 AM
71 delta88guy
Dec 18, 2012 08:11 PM
monzaz
Sep 4, 2010 03:50 AM
