Differential ID Problem
Old Jul 13, 2013 | 06:54 AM
Nighthawk's Avatar
Question Differential ID Problem
Trying to change the differential fluid on my car and can't figure out if it takes the regular stuff or the special anti-whatever lubricant. I guess the id is suppossed to be on the front of the passenger side axle tube but all I can make out is "0 288". I think there is supposed to be some letters in there somewhere but even after wirebrushing at it I don't see anything there. Any tips? I'm pretty sure it just takes the regular lubricant.
Thanks so much.
Old Jul 13, 2013 | 06:56 AM
Nighthawk's Avatar
My manual says there should be a two letter code right before the "288" which I am assuming is the manufacture day?
Old Jul 13, 2013 | 07:10 AM
Octania's Avatar
Trans in N
Lift ONE rear wheel
If it spins and turns the drive shaft, then there is no LSD/posi, so no additive needed
You will have the cover off anyhow right? At that point you can visually discern if there are just differential gears or some additional pieces for LSD [Limited Slip Differential; not the hallucinogen].
Worst case, get the posi additive- it can do no harm in a std open differential.
Old Jul 13, 2013 | 08:51 AM
Nighthawk's Avatar
74 Omega
Drivetrain/Differentials
Apr 3, 2008 03:00 PM
Omicron
Sep 4, 2007 06:50 PM
66starfire
20
Feb 2, 2007 01:26 PM
y30786
Oct 31, 2006 05:16 PM
rocketman67
Jun 21, 2004 04:06 PM
