Clutch chatter
Old August 2nd, 2017, 01:47 PM
Napoleon1991's Avatar
Clutch chatter
Recently I replaced the th350 in my 69 cutlass with a 4 speed. Everything went smoothly and I have had no problems with it until a few days ago. After its warmed up, the clutch chatters bad in 1st or reverse when engaging the clutch from a dead stop. Its totally smooth when releasing the clutch from a rolling stop but shakes the whole car when starting from a complete stop. This problem only happens after driving the car for about 10-15 miles and warmed up. I removed the bellhousing inspection plate and didnt see any oil on the flywheel or clutch. Ive put over 4000 miles on since the 4 speed swap with no issues until now. Pedal freeplay is at 1 inch like its supposed to be. Clutch is a centerforce II. Any advice would be helpful. Thanks.
Napoleon1991 is offline
Old August 2nd, 2017, 01:54 PM
joesw31's Avatar
What kind of transmission do you have Muncie M20, M21, or T-10- etc. What is the rear end ratio? What kind of flywheel did you use?
joesw31 is offline
Old August 2nd, 2017, 01:59 PM
muncie m20, 3:23 rear end, centerforce flywheel
Old August 2nd, 2017, 02:06 PM
joesw31's Avatar
There could be a few issues. One is the flywheel or the pressure plate may have developed hot spots; Two, the disc fits poorly on the input shaft splines, Third, the disc gets "sticky" when everything is hot. I had a similar problem many years ago, and it was the clutch disc. The bottom line is that to cure the problem you need to drop the trans. I am not a big fan of centerforce clutches.
joesw31 is offline
Old August 2nd, 2017, 02:09 PM
So your saying it could be a defective disk? Is this common with centerforce cluthes? I did check the disk on the splines before I installed it and it seemed to fit well.
Old August 2nd, 2017, 02:13 PM
joesw31's Avatar
The disc may not be defective, it could be the materials that they are using. I see a lot issues with centerforce clutches, therefore, I don't use them.
joesw31 is offline
Old August 2nd, 2017, 02:20 PM
Also, I forgot to add that when its warmed up, the clutch pedal feels stickier and not smooth. This is whether or not the engine is running.
Old August 2nd, 2017, 02:21 PM
joesw31's Avatar
You can see members here having issues with centerforce. Look up dave siltman, and you will see the issues he had.
joesw31 is offline
Old August 2nd, 2017, 02:24 PM
joesw31's Avatar
If the car is not running, the clutch pedal should feel the same as if it was cold, regardless. What release bearing did you use? Was the bearing retainer changed on the trans? Also, did you measure the air gap?
joesw31 is offline
Old August 2nd, 2017, 02:37 PM
centerforce release bearing. New bearing retainer on trans. Did not measure the air gap yet. What should it be?
Old August 2nd, 2017, 02:43 PM
joesw31's Avatar
Air gap should be .030 to .040.
joesw31 is offline
Old August 2nd, 2017, 02:46 PM
joesw31's Avatar
The only sure way to diagnose your problem would be thru dis-assembly, and thoroughly inspect all of the components.
joesw31 is offline
Old August 2nd, 2017, 04:01 PM
Thanks for your responses. I guess I know what im doing this weekend. Also, what clutch brand would you recommend?
Old August 2nd, 2017, 04:07 PM
joesw31's Avatar
I use Hays street clutch in my W-31, and have used them for many years. When you pull the trans be sure to inspect carefully all of the items we discussed. Good luck
joesw31 is offline
Old August 3rd, 2017, 02:16 AM
shiftbyear's Avatar
As the previous post suggest, dropping the trans is the solution. The problem may jump out at you right away. I used a Ram clutch with good results, McLeod is very good also. Sounds like Hays is also a quality brand. I seemed to have had the same problem once caused by weak pressure plate spring. Good luck, there are several diagnosis charts if you search.
http://www.benplace.com/vw_clutch2.htm
shiftbyear is offline
Old August 19th, 2017, 04:11 PM
For anyone who may have seen this thread, I thought I would post the solution to this problem. Turns out my motor and trans mounts were trashed and after replacing them, I havent had any more clutch chatter. Clutch pedal movement is also much smoother. I learned my lesson as I should have replaced the mounts when I had the engine out, but at least it was a relatively simple fix.
Old August 20th, 2017, 01:28 AM
shiftbyear's Avatar
Thanks for posting, that wasn't in the clutch chatter diagnosis chart. Good call. Nice to have this knowledge if I ever get stumped.
RandyS
July 6th, 2021 07:45 PM
96powerstroke
May 29th, 2017 03:10 PM
47 Convertible
April 3rd, 2014 07:56 AM
RandyS
March 8th, 2014 05:07 AM
Beob
July 18th, 2011 07:24 AM
Quick Reply: Clutch chatter
