Bell housing alingment
Old Jan 23, 2015 | 11:47 AM
Nilsson's Avatar
I am replacing the stock bell housing (cracked) on my 68 442 with another stock bell housing. It has a 4 speed that is original to the car. Is it necessary or recommended to align the bell housing being I am replacing it with one from another car? I believe I am over thinking this.
Old Jan 23, 2015 | 02:02 PM
It's basically self aligning to the dowels and bolts. You should be fine.
Old Jan 23, 2015 | 02:14 PM
garys 68&72's Avatar
Stock bells are pretty close and muncies are pretty tolerant of runout.
If it's a Chinese repop, that's another story. Last one I zeroed was 0.020 out.
Old Jan 23, 2015 | 03:13 PM
Nilsson's Avatar
I appreciate the replies. I won't give it a second thought, and put her back together.
Old Jan 23, 2015 | 08:38 PM
Run to Rund's Avatar
I always use aftermarket housings, and have found that they are usually .010 to .020" out. The misalignment is hard on stuff, and racers always use offset dowels to bring the alignment as close to 0.0 as possible. You can use a long spring center bolt in 7/16" x 20 on one crank flywheel hole, and fix the dial indicator to it.
Old Jan 23, 2015 | 10:02 PM
wr1970's Avatar
Why not weld it?Just because it's cranked that isn't a real good reason to replace it
coppercutlass
Aug 5, 2014 01:10 AM
hueveaj
Oct 9, 2013 05:55 AM
silverriff
Nov 17, 2008 06:29 PM
dan2286
Jul 26, 2008 05:00 PM
ozoneblue
Aug 21, 2007 05:59 PM
