Back drive linkage clearance
Old Dec 7, 2021 | 01:29 PM
EdwardB's Avatar
I thought I would ask a question BEFORE I order parts this time. Has anybody had clearance issues/problems with their back drive linkage and driver side header? I have a 72 Supreme with a 455 and a set of Hooker Super Comp headers. Just afraid to waste the money. Linkage was absent when I purchased the car. Thanks
Old Dec 9, 2021 | 10:20 AM
EdwardB's Avatar
Heard from cdrod that his SBO has no problems with his Hookers and the back drive linkage so I ordered all the parts from Inline Tube. I'm assuming the geometry would be the same between SBO and BBO in the location involved so if it won't work I'll put up a post on this thread.
Old Dec 9, 2021 | 01:43 PM
Loaded68W34's Avatar
Back drive runs between trans, frame, and steering column, so the geometry of the back drive parts themselves and where they are located will be the same between BBO and SBO. It will only be the change in the position of the header. I know there are guys on here running BBO headers with column shift cars (as posted in your other thread, the back drive is the same as the shift linkage on a column shift auto) so you should be OK.
67abody
Oct 18, 2015 06:19 AM
lemoldsnut
Sep 24, 2014 03:30 AM
4424me
May 13, 2012 06:02 PM
66ninetyeightls
May 18, 2010 02:59 PM
stevengerard
Oct 29, 2008 07:21 PM
