68 Cutlass S Convertible Trans
Old May 23, 2012 | 12:12 PM
VikingBlue's Avatar
I guess the 'convertible' aspect is irrelevant, but can someone advise what trans the above car would have come from the factory with ?
Motor is 350 4 bbl
Old May 23, 2012 | 01:09 PM
olds1968's Avatar
member
i believe it came with the Jetaway 2 speed automatic
Old May 23, 2012 | 01:23 PM
VikingBlue's Avatar
thanks...am not familiar with that. Is it a perfectly good, reliable trans ?
Old May 23, 2012 | 01:38 PM
droptopron's Avatar
delete
They are reliable but are only a two speed.
Old May 23, 2012 | 02:07 PM
allyolds68's Avatar
With a 2.78 rear and stock tires they shift out of first at 72 mph
Old May 23, 2012 | 02:48 PM
Octania's Avatar
aren't all the jetaway transes also switch pitch?
Old May 23, 2012 | 03:07 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
A 350 4 barrel RPO Cutlass could have had sevaral transmissions to choose from depending what options it had, as some options required manditory items. I beleive the M31(2 speed) was the standard trans if no options were checked off? Stick shifts were a popular upgrade to a 3 or 4 speed stick, though very rare. The 6 cylinder cars had either the M11 (3 on the tree) or the M31. But I've seen exceptions to these rules too such as a 3 speed stick equipped 6 cylinder convertible.
And no not all jetaways were switch pitches. One way to ID one is to look for a 2 spade electrical connector on the trans which would control the converter vanes though this is not always definitive. The best way is to look at the converter.
Last edited by droldsmorland; May 24, 2012 at 06:40 AM. Reason: Mike found an error in my data
Old May 23, 2012 | 07:38 PM
allyolds68's Avatar
A 350 4 barrel RPO Cutlass could have had sevaral transmissions to choose from depending what options it had, as some options required manditory items. I beleive the M31(2 speed) was the standard trans if no options were checked off? The M38 (TH350) was a popular upgrade as was a 3 or 4 speed stick, though very rare. The 6 cylinder cars had either the M11 (3 on the tree) or the M31. But I've seen exceptions to these rules too such as a 3 speed stick equipped 6 cylinder convertible.
I might be wrong but I don't think there was an M38 option in 68, only M40 (TH400)
Old May 24, 2012 | 06:42 AM
Mike,
Yes, I stand corrected 1969 was the first year for the TH350 not 68. The TH350 took the place of the M-31 (2 speed)
70SXchris
Feb 24, 2012 05:02 AM
Flye
Apr 18, 2011 04:24 PM
70SXchris
Mar 25, 2011 09:31 PM
64Super88
May 15, 2010 07:24 AM
djsoldzparrts
May 22, 2008 12:53 AM
