67 kick down
Old Jun 25, 2023 | 02:45 AM
Benny23's Avatar
67 kick down
Bought this sweet 67 olds the owner says kick down wasn't hooked up any help it's a 330 engine with an auto 3 speed
Old Jun 25, 2023 | 03:33 AM
cfair's Avatar
Have a look here:
https://classicoldsmobile.com/forums...vicing-149216/
Chris
Old Jun 25, 2023 | 06:08 AM
The original trans in your 67 had a switch pitch torque converter in addition to the electric kickdown. The switch on the firewall has three terminals, +12V power in, signal out to the switch pitch solenoid, and signal out to the kickdown. The trans should have a two terminal connector on the case. The harness from the switch to the trans is available new. The wire that powers the switch comes from the firewall connector.
Old Jun 25, 2023 | 06:30 AM
Benny23's Avatar
Thanks I don't see the wires on the firewall but it looks like there's a rod connected to the firewall that connected to the carb it has three wires on it my test light shows there's power at the fuse on both sides
Old Jun 25, 2023 | 06:33 AM
How about a photo, since your description is a bit ambiguous. You should see +12V on the yellow or orange wire with the key in the RUN position. The terminal for the switch pitch will have power with the throttle at idle, the kickdown will not. As you press the pedal, both terminals should have no power at part throttle, then both should have power at wide open throttle.
Old Jun 25, 2023 | 06:34 AM
Benny23's Avatar
Yep I send pics after work sorry this is all new to me
Old Jun 25, 2023 | 01:20 PM
Benny23's Avatar
Here's the pic
Old Jun 25, 2023 | 01:44 PM
cfair's Avatar
That's the Littlefuse non-adjustable design. Didn't know they used them in Cutlasses. Not too surprising though.
Test it with your test light as Joe mentions above and if you're not getting power to the switch pitch and/or kickdown pins, the brass contacts inside the with may be worn down too far to make a connection.
There aren't replacements I'm aware of, but you can solder some replacement points onto them to get connectivity back.
Chris
Old Jun 25, 2023 | 01:57 PM
Benny23's Avatar
No power to anything with key on not the yellow or orange wire
Old Jun 25, 2023 | 09:02 PM
Well, figure out why. Start with the TRANS fuse.
Old Jun 26, 2023 | 08:56 AM
Benny23's Avatar
There's power on both side of the fuse in the fuse block marked trans
Old Jun 26, 2023 | 11:25 AM
Ok, now trace the wire from that switch on the engine side of the firewall back to trans fuse. You are losing power somewhere.
Old Jun 26, 2023 | 02:49 PM
Benny23's Avatar
Ok orange wire goes to fuse block the yellow and black wire go from block on the firewall to the transmission
Old Jun 26, 2023 | 05:26 PM
Ok, so do you have power on both ends of the orange wire?
Old Jun 26, 2023 | 05:32 PM
Benny23's Avatar
No I have to dig deeper into this to see why it's not working
Old Jun 27, 2023 | 05:33 AM
Benny23's Avatar
Is there a wire diagram out there for this car it will help me trace the wire thanks for all the help guys I am learning lots from you
Old Jun 27, 2023 | 05:37 AM
The wire goes from the fuse box to the firewall connector to the switch. The total length is about 3 ft. Frankly we've spent more time talking about this than it takes to trace that wire. A diagram isn't going to tell you any more than that. Personally I'd look at the firewall connector as the problem.
Old Jun 27, 2023 | 06:31 AM
Benny23's Avatar
Thanks I will look today it's cooler today thanks for your help
aqua67w30
Paint
Sep 14, 2022 03:51 AM
jcdynamic88
Jan 31, 2022 05:03 AM
dc2x4drvr
Dec 29, 2014 07:19 PM
dukenfoof
May 19, 2013 12:20 PM
67Olds442X2
Aug 11, 2012 04:43 PM
