455 with a TH350
Old Jul 28, 2012 | 12:29 PM
btrbill's Avatar
455 with a TH350
Got a 71 Cutlass I bought that has a 455 bolted up to a TH350? I know this is a good tranny, but is it good enough to use with a 455? I have a 350 engine I could drop in but really do not want to.
Thoughts?
(PS... did a search and couldn't find a thread that contains this. If there is one, kindly redirect me there to avoid duplication)
Old Jul 28, 2012 | 12:43 PM
Rickman48's Avatar
Of course, a 400 would be better, but a 350 w/a shift kit should live a while.
Old Jul 28, 2012 | 12:50 PM
ah64pilot's Avatar
Bill, it'll live...but keep an eye out for a TH400. It would be a good thing to change it eventually.
Old Jul 28, 2012 | 01:24 PM
btrbill's Avatar
I actually have a TH400 but I am not sure of its condition. It supposedly came out of a running Vista Cruiser. I have been holding on to it... just in case! LOL
Old Jul 28, 2012 | 01:25 PM
btrbill's Avatar
Also, if I change it out, do I not need to redo the driveshaft as well?
Old Jul 28, 2012 | 01:39 PM
ah64pilot's Avatar
If that trans came out of a Vista it is going to have the long tail shaft. You would need to find another one or change the tail shaft out. You will also have to change the yoke to a TH400 yoke and shorten your driveshaft by about 1" (measure first) when switching from TH350 to TH400 short tail.
I just did it yesterday, cost $136 in Humble.
Old Sep 12, 2013 | 09:34 AM
tangokilo's Avatar
Thoughts?
Old Sep 12, 2013 | 03:48 PM
ELY442's Avatar
I like the low gear on the TH350. Give it a try.
Old Nov 25, 2013 | 01:04 PM
grmchne78's Avatar
I have had an Advance Auto (Accurate brand) reman TH350 witha shift kit behind my 455 for 4 years, I drive it to an 1/8th mile track and thrash it occasionally and drive it home with no problems. My car is not fast, but runs respectably with consistent 8.40's around 82 mph. If that helps... I would rather keep it that way than go TH400 due to all the (g-body) crossmember mods, driveshaft length changes....
CLcutlass
69
Nov 10, 2012 08:41 AM
70cutman
May 22, 2011 09:03 AM
1970_442
Oct 25, 2010 07:09 PM
john71
Jul 24, 2010 03:23 PM
sacksenheim
Jul 18, 2008 05:01 PM
