455 to TH350 trans tolerance problem
Old Jul 7, 2010 | 09:27 AM
john71's Avatar
Ok guys I need some help here. I had a 71 350 with a professionally built TH350 trans bolted to it. I have since sold the 350 and had a 70 455 rebuilt to put in my car. When i bolted the trans to the BB the torque converter was tight against the bellhousing and so tight against the new flexplate I couldn't turn the converter to align the bolt holes. The trans housing is a 78 which some refer to as the metric trans. Again this trans was mated to a 350 with no issues. My fears of course are there is not enough clearance (tolerance) to allow some flex in the flexplate etc. thus tearing apart the trans pump and who knows what else. The torque converter is about 12 inches dia x 6.5 inches deep (stock to my knowledge) Please advise and Thanks in advance
Old Jul 7, 2010 | 09:37 AM
svnt442's Avatar
It sounds to me like the torque converter is not seated properly. It should sit back about an inch from the face when fully seated in the pump.
Old Jul 7, 2010 | 09:45 AM
john71's Avatar
Randy, Converter is seated all the way. It is sitting 1/8" away from bellhousing on bottom near pan. Thats what has me puzzled. I know the converter is seated all the way but yet stiil tight against flexplate no room to turn it
Old Jul 7, 2010 | 10:02 AM
OLDSRALLYE350's Avatar
If you can get your fingers between the torque converter and the front pump in the transmission it is not all the way back. Best way i know to check it.
Old Jul 7, 2010 | 10:07 AM
john71's Avatar
No way to get my fingers to front pump. Converter is tight to bellhousing. Thanks
Old Jul 7, 2010 | 10:24 AM
svnt442's Avatar
Well I can tell you the dimentions of the 350 and 455 in that area are identical.
Old Jul 7, 2010 | 10:47 AM
Bluevista's Avatar
Registered
Something's wrong, have to have at least an 1/8th to 3/16th of an inch play between the flexplate and converter or you will mess things up.
Did they use a different size/depth converter for a 455 with a turbo 350?
Old Jul 7, 2010 | 11:40 AM
svnt442's Avatar
No.
Like I said the 350 and 455 have the same dimensions in that area of the block and crank.
Also the TH 350 and TH 400 use the same torque converter and the bellhousing dimensions are the same so the only answer is the converter is not seated properly.
Old Jul 7, 2010 | 11:59 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO John. I hope you can get the problem worked out.
Old Jul 7, 2010 | 01:04 PM
drec02's Avatar
Make sure you have a BOP torque converter or it won't seat properly and will cause the binding issue. Learned the hard way!
Old Jul 7, 2010 | 03:29 PM
john71's Avatar
Thanks guys. Well I do know the converter is seated. I even had a guy over that has been building BOP engines & trans etc for years and he can't understand it other than a converter issue. He has also verfied converter was seated so we're still workinging the issue.
Old Jul 7, 2010 | 06:30 PM
64Rocket's Avatar
Don't want to sound to silly, but are the bolts still in the bolt lugs? Also make sure you are not hung up on the counter weight on the flex plate.
Gene
Old Jul 8, 2010 | 01:30 PM
john71's Avatar
Gene, no statement is silly at this point. The bolts were removed and on the ground beside me. Also looked at counterweight issue. No issue there. The issue is strictly a forward and aft clearance. Thanks for your input and guidance.
Old Jul 8, 2010 | 02:19 PM
70 cutlass s's Avatar
If it was me I would drop the transmission and pull the tq. conv. then seat it. Just to make sure it was right.
Old Jul 9, 2010 | 09:14 AM
john71's Avatar
Trans has been dropped 3 times and re seated tq each time. Re looked at new flexplate all is good there. The only thing that does come to mind is i bought the motor used. I have heard of guys using the 425 crank in 455's for destroking them. Does anyone know if this could be the case?
Old Jul 9, 2010 | 10:05 AM
The 425 and 455 crank flanges stick out the same amount from the rear face of the block, so that isn't the issue.
Old Jul 9, 2010 | 02:02 PM
john71's Avatar
Thanks Joe. Just grasping here trying to figure this issue out.
Old Jul 9, 2010 | 02:25 PM
jpaulwhite's Avatar
Wow im interested now. Im planning on swapping a 70 455 for a 69 455 this weekend. In a 70 Olds 98. Crossing my fingers that nothing goes wrong.
Old Jul 24, 2010 | 03:23 PM
john71's Avatar
Ok Guys I got it. I changed the torque converter and it worked. After measuring everything again I found that the problem child was actually almost 13" diameter. A friend told me it may have been an issue of the converter going bad. He said they balloon sometimes. Can't say for sure but I know the new one mounts just fine. Thanks to all for your input and help.
rocketraider
May 3, 2013 06:41 PM
RAMBOW
Jan 25, 2011 09:00 PM
Bryan59EC
Jun 4, 2010 07:23 AM
CHEV VAN
Jan 25, 2010 07:51 AM
chadnum1
Apr 30, 2008 11:12 AM
