1979 Hurst Olds Dual Gate Shifter Installation
Old May 31, 2018 | 05:24 AM
carlsongb's Avatar
Cool 1979 Hurst Olds Dual Gate Shifter Installation
Hi all,
Just bought a dual gate Hurst shifter from a 1979 Hurst Olds and want to install it in my 1980 Olds 442 W-30.
I have looked online and cannot seem to find a schematic on how the 1979 dual gate shifter is installed. Does anyone have any tips and or diagrams that will help in my installation?
Thank you for your time,
Glen
Old Nov 13, 2022 | 04:20 PM
Gerald Nickels's Avatar
Isnt that the same shifter used in 70-72 Hurst just different brackets ?
Old Dec 17, 2022 | 09:03 PM
Hoffa65's Avatar
no. different cable routing and length
Old Dec 18, 2022 | 09:54 AM
TRFREE's Avatar
I believe the shift cable is different also.
Old Dec 18, 2022 | 11:20 AM
69HO43's Avatar
And the way it mounts. Sort of. Brackets are different and you'll have to modify the console section a bit.
If you got the brackets and the top plate, you're miles ahead. Yes, the cable is different, but from what I've heard (I've never done it personally) the brackets line up with the regular shifter mounts. I could be wrong on that, however.
Note in the console pic below there's a small section of the console that doesn't get cut for the bolt to attach to the front bracket on the driver side. Same for the RH side, but it's sorta out of the way.
69442murph
Mar 27, 2022 06:20 AM
mrolds69
Apr 10, 2018 07:58 PM
69442
Oct 24, 2015 06:26 AM
fast67vellen2o
Jul 26, 2015 11:48 AM
69OLDSCUTCONV
Jun 26, 2011 07:18 AM
