wire harness for TH 400 Kickdown
Old Feb 23, 2020 | 12:11 PM
sherlock1212's Avatar
I'm changing out my TH350 for a 400 and I need to find the wire harness for the kickdown Any help would be great thanks
Old Feb 23, 2020 | 12:52 PM
4speed455's Avatar
The harness is built into your existing harness it’s usually just taped up. You will need the switch and bracket and either remove the tab for the th350 kick down cable or replace the gas pedal.
Old Feb 23, 2020 | 01:41 PM
svnt442's Avatar
What year is your car?
Old Feb 23, 2020 | 06:02 PM
it's a 68 cutlass s it cam with a 2 speed jetway I changed it to a 3 speed so I never a wire running to the trans
Old Feb 24, 2020 | 03:04 AM
svnt442's Avatar
The Jetaway uses an electronic kickdown just like the TH400 so all of the wiring should be there unless it was torn out when the TH350 was installed. Also the kickdown switch should be mounted on the gas pedal, again, unless it was removed when the TH350 was installed.
Old Feb 24, 2020 | 03:40 AM
If the switch and wiring is still under the dash (pink and orange wires with a 2 terminal connector body) all you need is a series 56 male terminal and enough wire to reach the kickdown solenoid. American Autowire sells the correct wire and connector body for a factory look. It would be great if all the original stuff is still there, makes the swap easy.
RROLDSX
May 7, 2017 07:08 PM
kad36
Jan 21, 2017 06:10 AM
jensenracing77
Oct 4, 2014 08:39 AM
TheBigBlueBoat
Apr 10, 2013 01:48 PM
DRXOLDS
Apr 24, 2011 07:52 PM
