Where's my bell housing?
Old Nov 17, 2008 | 06:34 AM
silverriff's Avatar
1972 Cutlass 455
Question Where's my bell housing?
O.k., stupid question.... I do not have a bell housing on my 1972 Cutlass 455. The fly wheel/torque converter are all out in the open. Is that normal? Did someone just take it off and not put it back on? And if its not on there, should it be? HELP I'm scared!!
Old Nov 17, 2008 | 06:44 AM
Bluevista's Avatar
Registered
If nobody answers before me, I think the cover is missing on the bottom.
Allan
To be more specific the flywheel, clutch, or converter housing cover.
I was watching the Barrett-Jackson auction and more than a few big buck cars had them missing too.
Old Nov 17, 2008 | 07:29 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Yeah, sounds like your inspection plate is missing.
http://images.google.com/imgres?imgu...3Doff%26sa%3DG
Old Nov 17, 2008 | 11:53 AM
csstrux's Avatar
All you are missing is a tin plate that is called a dust shield. The housing is cast as a single unit with the body of the trans. I'm not sure but would assume any dust shield off an Olds of similar vintage will bolt up in place. But all in all it probably isn't necessary. I have had countless cars over the years that have not had them on without a problem. Keep in mind I used to run A LOT of beaters.
Old Nov 17, 2008 | 06:29 PM
citcapp's Avatar
Based on your information You do not have a transmission all you have is the flywheel and torque convertor. In order to have a Bell housing you would have a stick transmission with a flywheel, clutch plate, and a pressure plate
jensenracing77
Dec 20, 2022 12:37 PM
brandon reynolds
Mar 16, 2010 07:02 PM
mono-plane
Oct 15, 2009 04:40 PM
dan2286
Jul 26, 2008 05:00 PM
ozoneblue
Aug 21, 2007 05:59 PM
