What Trans.
Old Nov 21, 2008 | 01:26 AM
WEBBISH's Avatar
What Trans.
I have a 66 delta 88 2DR HT 425Ci i've been told it is a TH400 and is common to have an elect. kick down. I was messing with the fusses and broke the one marked trans. it was a 9V when i drove the car it wouldn't kick into 2ND had to shift it. I finnally replaced the fuss and now it works fine again. Stomp on it and it kicks down just fine it is a 3 SPD auto TH400 or ????? thanks for aany info WEBBISH
Old Nov 21, 2008 | 02:12 AM
dynamic88's Avatar
right would be same tranny i have in my 65 dynmaic 88. they are good trannys chris
Old Nov 21, 2008 | 06:16 PM
citcapp's Avatar
It is a Turbo 400
Old Nov 21, 2008 | 10:17 PM
BILL DEMMER's Avatar
Just the facts...
it should be a switch-pitch thm400. you should have two wires connecting to the trans.
bill
Old Nov 24, 2008 | 09:01 PM
WEBBISH's Avatar
Is this a good tranny love the way it shifts real smooth i've had cable shifts and they can be a pain just easier to shift, but that was a floor shift Camero I guess I'm gettin older because I like the ride to be softer these days and more room to spred out but still love to feel the power from that 425BB really like the site thanks P.S. what is switch-pitch just the name for elect.kick down?
Old Nov 25, 2008 | 11:24 AM
The TH 400 is quite possibly the toughest automatic transmission in the ENTIRE WORLD!
Switch pitch refers to the ability of the transmission to change the pitch of the vanes in the torque converter.
Old Nov 25, 2008 | 11:50 AM
rocketraider's Avatar
Oldsdruid
These are Turbo 400s, which all have ELECTRIC kickdown. That's why it woudn't downshift when the fuse was out. You probably also saw some weird stuff with your idiot lights since they generally feed off the TRANS-GAGES fuse.
The switch-pitch part of the torque converter changes stator blade angle to match engine load requirements. Good idea in theory and great when it's working. Switch pitch was used 1965-67 in Buick, Olds and Cadillac applications.
Old Nov 25, 2008 | 12:30 PM
Redog's Avatar
Great tranny. The only downside is no overdrive.
Can handle about 12,000 ft lbs of torque, in stock form
Flye
Apr 18, 2011 04:24 PM
64Super88
May 15, 2010 07:24 AM
cutlass72
Jan 2, 2004 05:26 PM
<Cody>
Aug 10, 2003 10:00 PM
