What automatic transmission did the 66 442 have?
I believe that's the first time I've heard the Super Turbine 300 used by someone other than me. When I ran my Chevy's in NHRA/IHRA Stock Eliminator I used A-! Automatic Transmissions and Convertors. A-1 was a premier vendor for such parts and Marv Ripes the owner told me he used the Super Turbine 300 clutches in the powerglide trans. That was the first place I heard that term used back in 70's. Thanks Joe for bringing back some good old memories.
ST300 was the GM transmission name from Hydramatic Division, just like TH350. Olds decided that they needed a special marketing name. Buick did not. Pontiac also called it the ST300.
Buick called it a Super Turbine 300. The DID NOT call it a ST300 which was the GM name. Seems different to me but what the hell do I know. I only worked for a Buick dealer during the period. Of course I should realize I am talking to the guy that knows everything.
TH = Turbo Hydramatic
Sorry, but you are reading waaaay too much into my laziness.
The primary difference was that Buick and Olds used the switch pitch converter behind V8s for the 1964-67 model years. Pontiac and six cylinder Buicks and Oldsmobiles did not use the switch pitch. The version used behind big blocks in the 1965-66 442s were beefed internally and used different calibrations, obviously.
