Wanted: Hydra-Matic Transmission Tool Set
Old Jul 29, 2010 | 06:22 PM
Larry Q's Avatar
Wanted: Hydra-Matic Transmission Seal Puller/Installer
In need of a rear seal puller/installer for a 1955 Oldsmobile Hydra-Matic transmission. Kent-Moore Part Numbers: J5930, J5948, J5946
Thank you very much!
Old Jul 30, 2010 | 07:16 AM
d2_willys's Avatar
1955 Oldsmobiles used a dual range hydramatic, turbo hydramatics came out in 64. If you are looking for tools for the older hydramatic, check EBAY. They recently had a really nice set of tools from snap on. Went for a couple of hundred. You can get the seal out of the older hydramatic with a typical seal puller, and to install it get a galvanized pipe coupling and cap that is the same size as the seal. Screw the cap to the coupling and use that as a driving tool.
Old Jul 30, 2010 | 05:34 PM
Larry Q's Avatar
Thanks for the info. Mr. Bundy..great pic
BenJammin
Jan 7, 2014 11:55 AM
Larry Q
Jul 29, 2010 07:20 PM
Larry Q
Jul 29, 2010 06:26 AM
thoogylives
Jun 16, 2010 06:12 PM
American Lead
Nov 16, 2008 04:10 PM
