vacuum modulator
Old Nov 7, 2010 | 12:01 AM
1973olds98's Avatar
vacuum modulator
i was pulling my intake off and noticed when i was disconnecting the vacuum lines i had some tranny fluid run out of the line the connects to the small tube the runs down to the tranny vacuum modulator...My question is,,,Should the intake vacuum suck tranny fluid out of the modulator or is the modulator bad and need replaced..
Old Nov 7, 2010 | 03:11 AM
Rickman48's Avatar
Yes, it''s bad! Vacuum diaphram [rubber] cracked!
Aftermarket ones from B+M are adjustable, [small screwdriver down the tube] and let you 'fine tune' your shift points!
Old Nov 7, 2010 | 10:56 AM
1973olds98's Avatar
ok thanks
TripDeuces
Tech Editor's Desk
Jun 11, 2010 01:53 PM
sworthy555
Feb 26, 2009 06:13 AM
Chris Browning
Sep 17, 2008 12:08 PM
chivo80026
Jul 3, 2008 08:51 AM
joe_padavano
Tech Editor's Desk
Jun 18, 2008 07:11 PM
