Unknown wires above transmission
Got the Cutlass home and am going over it. While under the car I discovered a couple of wires that come together at a rubber boot. I can't tell where they originate. And they were not hooked up.
Can anyone shed some light on what this is?
Those are the kickdown and TCS wires for the TH400 option. I assume your car has TH350? The harness had the TH400 wires in it anyway. They were just taped out of the way if the car came with a TH350.
Thank you sir for the response. Same info confirmed after I posted the thread in the electrical forum.
Thanks again
