turbo 350 problem
Old Jan 31, 2008 | 08:05 AM
abody's Avatar
turbo 350 problem
i have a 70 cutlass 350/4 barrel, when i floor it the 4 barrel opens good, but it doesn't kick down any gears it just goes, but if i manually shift it it feels quicker, how do you adjust the trans to get it to kick down? the car is all stock with low miles.
Old Jan 31, 2008 | 10:06 AM
First question - is the kickdown cable from the trans to the accelerator pedal in place? If so, the cable is adjusted by moving the spring clip where the cable end passes through the accelerator arm.
matviar
Feb 26, 2012 11:05 AM
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
