Transmission valve.
Transmission valve.
My 1950 Olds 98 is missing the transmission valve rod. The engine and carborator are not orginal to the car. The engine is a 1957 371 cu. I do not quite understand how this valve works. I believe that it is attached to the throtle linkage via the tv rod. Does this valve stay open while the tranamission shifts ? What postion is the valve open toward the engine or toward the rear of the car ? Is it possible to fabricate a rod that would work ? I do have a Rochester two barrel carb from a 1950 303 cu. that maybe I could use the linkage from. I just had the transmission rebuilt and they tell me without the tv rod it will be damaged besides it does not shift as it should. Thanks for any imput.
Although not familiar with that particular transmission, the rod works like the cable on a modern O.D. transmission.
As you depress the gas, it increases the line pressure which will give a firmer shift, and overcome the weights/pressure that are set to determine the shift itself.
Without the rod adjusted properly, you're inducing the shift at low pressure, causing slippage, which will cause premature failure.
If I rebuilt it, I wouldn't warrantee it unless I installed the rod, and knew it was adjusted properly!
Both need TV rods, but the 371 had some different linkage then the 303 engine had. The TV rods themselves are similar, but I would go with the rod that matches up with the transmission.
Years ago I had a 60 Olds 371 and dual range hydramatic. I ended up making an adjustable bell crank (linkage at the rear of the left cylinder head) to accomodate the hydramatic TV rod.
The TV rod is toward the front of the car when WOT, to the back of car at IDLE.
Hope that helps.
Ron McHugh
May 15th, 2013 01:23 PM
