Transmission mount replacement
Old Apr 14, 2018 | 02:17 PM
dalilama's Avatar
Pretty sure the TH350 transmission mount in my 1972 Cutlass vert is worn out and I want to replace it. Is it a given I need to remove the crossmember to get at the bolts holding the mount to transmission after I remove the 2 bolts I can see? Or can I jack up the trans high enough to get at these without removing the crossmember. I'll be holding the trans up with a floor jack and a block of wood.
Old Apr 14, 2018 | 04:07 PM
You should be able to jack the trans high enough so that you don't need to remove the crossmember.
Old Apr 14, 2018 | 05:08 PM
dalilama's Avatar
I was hoping, so I'll give it a shot and let you know.
Jameskilcer
Nov 7, 2015 04:45 AM
1968_Post
Sep 12, 2014 07:32 PM
66ninetyeightls
Sep 4, 2011 07:06 PM
radman58
Mar 7, 2011 09:08 AM
iuhoops83
Dec 23, 2008 08:28 PM
