Transmission information
Old Mar 23, 2016 | 05:37 PM
Joffroi's Avatar
Runner
I'm looking to get more information about this transmission. I was told it was a 400 transmission but looking at the code it seems to say 74 OA. Does the board happen to have any information on this. Its suppose to be behind a 455 now and I couldn't find information about a 74 OA being a 400 even. Unfortunately, this is the only picture I have. Thanks in advance.
Old Mar 23, 2016 | 06:11 PM
In the 1974 model year, OA was the code for a TH400 used behind an Olds 350 motor in the Delta 88 line. This may have actually been a TH375 with the small output shaft.
Old Mar 23, 2016 | 06:19 PM
Joffroi's Avatar
Runner
That's the information I was coming up with when googling and wanted to make sure. Could that even be paired with a 455 engine? It just seems odd. And I see no reason why the stamp would be replaced or re-stamped.
Old Mar 23, 2016 | 06:31 PM
It should not have been installed behind a BBO from the factory.
Old Mar 23, 2016 | 07:19 PM
Joffroi's Avatar
Runner
Thanks for the confirmation. With that being said, is it even a viable choice to put behind a 455 and have a good driver and performance?
Old Mar 24, 2016 | 06:33 AM
Joffroi's Avatar
Runner
I did some searching around and from what I can tell, it seems like it may all check out. Tough to tell without know what is really set up inside I guess.
https://classicoldsmobile.com/forums...-vs-th400.html
https://classicoldsmobile.com/forums...vs-700-r4.html
restoman
Oct 7, 2009 01:34 PM
POKANOKET
Jul 14, 2007 02:58 PM
66starfire
Apr 1, 2007 07:25 PM
lou_harris
Jan 4, 2007 02:42 PM
<joyce>
Jun 11, 2004 12:16 AM
