Transmission Identification
Old March 29th, 2016 | 10:22 AM
RustyOlds's Avatar
1969 Oldsmobile Cutlass S
So I need some help identifying the transmission on my 69 Cutlass. I figure it's a TH400 considering my Cutlass has a 455cid Olds engine in it but I'm not quite sure. I have some pictures of the pan and of some id I found just before the drive shaft. If you can't read it, the pan says, "Hydramatic Division of GMC" however I couldn't make out the last letter on the GMC part
The pan
id on the tran just before the drive shaft
the pan again
Old March 29th, 2016 | 11:49 AM
Octania's Avatar
Tail housing of TH400 is attached with 6 bolts.
Lesser models have four.
Well, the TH375 is probably also a 6-bolt tail housing.
The hex vs 4-bolt pattern is extremely obvious.
Is there a trans ID tag on the RH side, flat tag nailed to the trans in the center of the tag? It will have good info.
Pretty sure that's an Indiana shaped TH400 pan.
SkylinesSuck
September 24th, 2015 05:20 AM
JPSTNCOLD1
March 14th, 2013 07:13 PM
trackz man
April 10th, 2011 10:13 AM
CaliBoricua
July 9th, 2010 02:12 PM
J-(Chicago)
January 9th, 2008 04:51 PM
