Transmission cooler hose fittings
Old Jan 27, 2023 | 11:57 AM
stanzaschance's Avatar
Good evening Oldsmobile enthusiasts! I'm in need of some assistance with finding correct fittings for my transmission hoses. I'm using the braided transmission hoses and I am in search of some an6 to 5/16 inch 90 degree fitting. Any help will do. Thanks!
Old Jan 27, 2023 | 02:37 PM
You can do a 45* fitting in the case, and use a 45* fitting to make a 90* degree turn, but a 90 won’t fit in the case. The end of the fitting hits the bellhousing long before it’s tight.
Keep in mind, just about every GM transmission uses fittings with sealing washers. Pipe thread will fit, but it’s really easy to crack the case.
This it what you need.
AK71CutlassS
Sep 9, 2022 07:58 AM
droldsmorland
Jan 17, 2018 05:09 PM
deaddds
Nov 15, 2016 05:33 AM
at3reg98
May 4, 2012 08:22 PM
Redog
Dec 29, 2007 09:13 AM
