transmission automatic to manual
Old Apr 23, 2008 | 01:57 AM
oldcars's Avatar
I have a 350 rocket golden edition and the transmission is a automatic and I would like to changed for a manual.It's possible or not!help about this tanks
Old Apr 23, 2008 | 02:40 AM
88 coupe's Avatar
Junior Member
https://classicoldsmobile.com/forums...onversion.html
Norm
Old Apr 30, 2008 | 07:32 PM
z11375ss's Avatar
Senior Moment Member
I am in the process of doing just this. I went on ebay and found a complete 4 speed. EVERYTHING, springs, z-bar, *****, flywheel,bellhousing, pedals, trans, etc. I then found a 4 speed crank and had the motor rebuilt with it being installed. So far no problems. This is the expensive way to do it but also the easiest.
Old May 3, 2008 | 06:01 AM
dognuttsx's Avatar
i have a three speed manual trans with every thing you need including streeing wheel call 937 2701823
Old May 10, 2008 | 09:52 AM
Read the link that Norm posted above. Your biggest problem is the pilot bearing recess in the crank (or lack thereof). By the way, ALL 350 Olds motors were painted gold (at least until the mid 1970s). The color means nothing.
Old May 10, 2008 | 12:48 PM
z11375ss's Avatar
Absolutely correct. I rebuilt my small block with the different crank so I could install the 4 speed. The most difficult part of the whole deal. I know there are jigs out there to drill the notch but am not sure how to get one or go about doing it. Good Luck!
rocketman77
May 6, 2015 04:15 AM
boese1978
Apr 27, 2012 09:20 AM
jasm8
Aug 14, 2011 05:32 AM
2blu442
Mar 5, 2010 02:27 PM
ztim
Sep 12, 2006 09:41 AM
