1984 Delta 88 automatic transmission
Old Sep 8, 2006 | 04:24 PM
ztim's Avatar
Ok...there is a drip of transmission fluid coming from, I think, the bolt head at the bottom of the "pan." It is right under the transmission. Is it a drain?
Is there a special gasket for that bolt? I was told there is a copper one and it may have been re-used.
Is the pan removable with no problem if the gasket just needs to be replaced? I mean, if I am going to change the fluid anyway I wouldn't want the guts to fall out.
Thanks again
Old Sep 9, 2006 | 09:19 AM
ztim's Avatar
Thanks Oldsfan. I am not sure about the type of transmission, it is mated with a 307 V8.
Old Sep 9, 2006 | 02:28 PM
Blk2001GAGT's Avatar
Hmm, have to check mine and see which bolt you're talking about and will get back to you.
Anyway, I have been having a problem with my transmission. It will not shift to Reverse when the car is first started but will shift into Drive, 2 and 1 normally. However, after the car is driven (at least 3-4 miles) and then stopped, it shifts normal into Reverse. Just wondering what this sympton indicate and how big of a problem could it be down the road if not immediately remedied.
Thanks in advance for all info. I'm in the process of determining my transmission type but like yours, I have a 307 Vin Y engine.
Anyway, hope you don't mine if I posted this on your thread (instead of starting another one).
Old Sep 11, 2006 | 10:26 AM
ztim's Avatar
Thumbs up
The code for mine is MV9
Old Sep 12, 2006 | 09:41 AM
ztim's Avatar
Thank you. I will see what comes out of it.
brandon 455
18
Nov 7, 2013 05:34 AM
Perry615
Apr 16, 2013 05:55 PM
classicmuscle442
Apr 3, 2013 08:29 AM
oldcars
May 10, 2008 12:48 PM
a6m5zerosen
Jan 3, 2008 02:57 PM
