Trans "Reprogramming"
Old September 25th, 2012, 02:36 PM
rcrac3r's Avatar
I have a 1972 Cutlass S with a 350 & original 3 speed tranny. The engine is going to be rebuilt over this winter, & I remember reading a post somewhere about putting a "re-programming" kit in the trans as opposed to a shift kit but I can't find it. Can anyone shed light on this?
rcrac3r is offline
Old September 25th, 2012, 04:46 PM
ah64pilot's Avatar
You can re-program a computer, but a Hydramatic TH350? I don't think so. There are no electronics in the TH350, and the TH400 only has an electric kick down switch. Unless someone invented something I am unaware of, you are going to have to put a shift kit in it.
Shift kits are easy to install, especially if you have the tranny out and on a stand. I used the Trans-go in my current transmission. I installed it in 1999 and it has been holding up ever since. I love it!
ah64pilot is offline
Old September 25th, 2012, 05:03 PM
Mr. Johnson
rjohnson442's Avatar
As in making it a full manual where you have to shift every gear?
rjohnson442 is offline
Old September 25th, 2012, 05:25 PM
bccan's Avatar
"Shift Kit" is a trademarked name iirc. Generic is reprogramming kit. Depending on trans & kit they will modify shift timing (along w/ governor mods), firmness, quickness of shifts, line pressures, etc. Soft shifts in auto trans mean slippage & heat, the two main killers. Quick, firm shifts are necessary for reliability & performance, the more power, the more important. Good comparison for those of us old enough would be to compare shift characteristics of OW TH400 vs TH400 that would have been used in a 98.
Different kits or mod options within a single kit can be selected by the installer to suit the needs of the application.
bccan is offline
Old September 26th, 2012, 11:23 AM
rcrac3r's Avatar
I found the links I was looking for. It explains about the "re-programming"
http://www.txchange.com/transgo.htm
and this one is for the manuacturer...
http://transgoonline.com/index.html
rcrac3r is offline
Old September 26th, 2012, 11:29 AM
Mr. Johnson
it's a shift kit...
Old September 26th, 2012, 03:08 PM
ah64pilot's Avatar
Originally Posted by rjohnson442
it's a shift kit...
X2...
15 years ago the trans go kit I got was called a shift kit. Now it's called the "Reprogramming kit - 400 Pro". Marketing
Old October 1st, 2012, 12:37 PM
rcrac3r's Avatar
Ok. They seem to word it as they have 2 different products, shift kits & reprogramming kits. So are Transgo kits fairly reliable? Anyone else used them?
rcrac3r is offline
Old October 2nd, 2012, 06:17 AM
The Trans-Go kits are a little more civilized, they keep the accumulators functional for comfort. If a high stall converter is in the car or is in the future I would use the B&M kits. They are more aggressive. The Trans-Go kits are pretty conservative with a a high performance converter. Some people will disagree, just my opinion.
matt69olds is offline
Old October 2nd, 2012, 12:04 PM
rcrac3r's Avatar
This will be a daily driver in the summer with a few visits to the strip. I'm thinking of putting no more than a 2500 stall converter in so which would be better, B&M or Transgo?
rcrac3r is offline
Old October 2nd, 2012, 06:23 PM
2500 is just a little looser than stock, I would use the Trans-go. The B&M kit severely restricts the accumulator function and has you drill the holes larger. Thats great if you want it to knock the dash out of the car when it shifts, gets annoying on the street day in and day out.
Old October 3rd, 2012, 07:01 AM
oddball's Avatar
Second on TransGo. I've run both and vastly prefer the TransGo for a driver.
oddball is offline
Old October 3rd, 2012, 02:21 PM
rcrac3r's Avatar
Ok Transgo it is. Now on their site they list a few for the 350 tranny...
http://transgoonline.com/products.ph...3&parent_id=93
Not sure which one I need. I'm guessing their 350 1-2 kit is like a Stage1 or Stage2 kit & the 350 3 is Stage3?
rcrac3r is offline
Old October 4th, 2012, 06:24 AM
oddball's Avatar
The -3 is a full manual valve body mod.
The 1-2 can be installed two different ways (with different mods) to change the shift feel. I think I went with the "stage 2" setup in mine, but it's been well over a decade.
oddball is offline
Old October 4th, 2012, 10:40 PM
Magna86's Avatar
TransGo is my choice. Used one in my 2000 Z71 and it helps greatly and isn't too hard. Just bewared their directions are not the greatest so just take your time.
Magna86 is offline
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
auto_editor
July 28th, 2011 08:20 AM
81 regency
April 21st, 2011 06:18 PM
Flye
April 18th, 2011 04:24 PM
64Super88
May 15th, 2010 07:24 AM
Quick Reply: Trans "Reprogramming"
