Trans doesn't go into gear when first start up
Old May 4, 2014 | 10:42 AM
Check6's Avatar
Have a 72 Cutlass with 350 engine and TH 350. When you first start the car
and shift the trans in doesn't go into gear . after shifting back and forth a few times it will engage and be all right. This only happens when the car has sat over night. It seems once it warms up it's OK. Fluid is full and has a shift kit installed.
Thanks,
Fred
Old May 5, 2014 | 06:38 AM
rjohnson442's Avatar
Mr. Johnson
The idle may be set to low. Mine was doing the same thing when cold, ran fine any other time.
CutlassS1972
Sep 22, 2014 07:20 AM
omg_its_nickels
Jan 31, 2010 02:53 PM
pophop
Nov 5, 2009 12:26 PM
mrveezi
Feb 15, 2009 04:58 PM
