Trans control spark issue
Old Jun 9, 2011 | 07:56 AM
Joe C's Avatar
Exclamation Trans control spark issue
I have a 71 cutlass with 350 transmission and trying to get trans control spark working. The switch at the transmission has one terminal and the connector harness has two terminals. Do i have the wrong switch or is only one wire need to be connected, if so whish one. Also how can i test the switch on the intake manifold. Thank for any help
Old Jun 9, 2011 | 08:39 AM
Originally Posted by Joe C
[I'm] trying to get trans control spark working.
Why?
Old Jun 9, 2011 | 12:37 PM
Originally Posted by MDchanic
Why?
My thoughts exactly. In any case, the reason why there is a two terminal connector at the trans end of the harness is because the same wire harness was used with the TH400, which has an electric kickdown as well as the TCS. On the TH400 the plug in the trans case has two terminals. Your TH350 only uses one of the two and the other is not connected to anything in your case. This was just a way for Olds to avoid needing two different wire harnesses.
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
fasteddi
Jun 28, 2012 07:49 PM
My442
Apr 30, 2012 07:12 PM
poorboy_616
Jul 18, 2010 02:07 AM
