tranny swap
If the Caprice has a Chevy motor then you are out of luck. The Olds 307 Uses the GM BOP (Buick, Olds, Pontiac) bellhousing bolt pattern. If you want to swap a Trans in, you will need to find a donor from a Older Cutlass.
Why would you want to perform this swap? This will change your final drive ratio, making highway cruising and gas milage a little less tolerable.
u can put a chevy tranny behind an olds motor or(B.O.P.) i f u get the bellhousing adapter plate.
look in jegs or summit, their like 50 bucks.
some 350 trannys have dual bell housing bolt patterns.
Winnipeg Cutlass
April 17th, 2006 03:15 PM
