tranny swap
Old Aug 10, 2003 | 09:11 AM
joelow83's Avatar
Post
i have an 83 old 98 the engine is a 307 200r4 iwas wondering is it possible to bolt up a th350 tranny out of a 78 caprice or is there a tranny that will bolt up to it with out alot of work.
Old Aug 10, 2003 | 09:54 PM
70ragtop's Avatar
Post
If the Caprice has a Chevy motor then you are out of luck. The Olds 307 Uses the GM BOP (Buick, Olds, Pontiac) bellhousing bolt pattern. If you want to swap a Trans in, you will need to find a donor from a Older Cutlass.
Why would you want to perform this swap? This will change your final drive ratio, making highway cruising and gas milage a little less tolerable.
Old Sep 25, 2004 | 03:56 PM
powerplant455's Avatar
Post
u can put a chevy tranny behind an olds motor or(B.O.P.) i f u get the bellhousing adapter plate.
look in jegs or summit, their like 50 bucks.
some 350 trannys have dual bell housing bolt patterns.
Old Jul 13, 2006 | 03:19 PM
goodwrench1984's Avatar
Keep it simple
Keep it simple and use the same trans, swapping parts can cause financial pain and other unforeseen problems.
Chris
TOONLOVESCHERYL
Feb 4, 2016 06:30 AM
papabear4208
May 26, 2007 07:24 AM
crank.it
Nov 12, 2006 04:04 AM
Winnipeg Cutlass
Apr 17, 2006 03:15 PM
JP63
May 19, 2003 02:05 PM
