Torque Converter best fit
Old Dec 13, 2009 | 08:06 AM
boondocker's Avatar
Where were you in '72?
What is the stock stall for a '72 TH350 tranny? I'm upgrading my SBO 350 to a comp cam K42-222-4 (XE262H) kit) and wanted to upgrade the stall on my transmission as well...what would be the best choice for mild street performance?
Old Dec 13, 2009 | 08:21 AM
70 cutlass s's Avatar
Power range for that cam is 1,200-5,600 which the stock converter is around 1,200 which means you don't need a higher stall speed. Stock converter is fine. You will need 3.08 to 3.23 gear in the rear end to take full advantage of the cam.
Old Dec 13, 2009 | 08:44 AM
boondocker's Avatar
Excellent...would posi make a real difference here?
Old Dec 13, 2009 | 09:00 AM
Posi is always better two tires putting power to the ground instead of one.
Stevec
Apr 20, 2012 05:46 AM
scrappie
Apr 3, 2008 06:41 PM
Fred H
Jan 24, 2008 07:58 PM
SPEEDROCKET
Dec 18, 2007 06:35 PM
Surfrat67
May 14, 2006 03:42 PM
