tko600 twisted yoke splines
What the hell'd ya do?? I ran one in a 4800lb F-150 Lightning with slicks with no problems. Several passes even on a drag radial. Oh, it was pushing about 500lb ft of torque out of a 4.10 rear end.
The yoke is inserted far enough. Whether or not it is heat treated I do not know.
The spline is displaced about ten thou if you look down the inside of it 3/4 of the length of it.
The yoke came from American powertrain along with the tko
Will a file test tell me if it is the cryo hardened version?
This will likely happen again
I can't say for sure that the trans output shaft is ok, but i suspect it is ok. We know it is hardened. Without dis-assembly I can't tell. It looks straight when inspected with a flashlight.
Daffy's Trike
Drivetrain/Differentials
May 10th, 2009 06:31 PM
Daffy's Trike
May 3rd, 2009 08:47 AM
